RCU Forums - View Single Post - e-flite cap 232 bp
Old 03-25-2007 | 04:41 AM
  #82
eugenefelisco
Default RE: e-flite cap 232 bp
ORIGINAL: RCAV8R1
ORIGINAL: eugenefelisco
Hi I need help on my set-up. Here is my set-up AXI2212/26 with 10x3.8SF,phoenix25,3TP1320,DX6 radio with 2HS55 and 2S75. My question did you guys do the right trust angle on the motor mount with AXI? And I need suggestions where I can put my HS55 and s75. Thank you very much.
I put right trust into my 2212/26 by using the two wedges provided in the kit, just follow the directions. The motor sticks out a little farther then I like (even when cutting back the motor mount stick) but it balances fine.
I would use the HS55 on the aileron and the S75 on the rudder and elevator but, you can reverse that. It really won't be a big difference.
Its a fun plane to fly I had to put in some mix in during knife edge flight, it pulled toward the gear on left rudder and pulled toward the canopy on right rudder.
Steve
Thank you very much Steve for that info. I have flown her a couple of times already. The CG is a bit tricky coz I put it 1 inch behind the leading edge of the wing and it balance well on my CG(4 3/4") mark. But when I flown her she is tail haevy. So I watched a couple of videos and tried to figure out the battery placement. Tomorrow I will try to play with the batt positions. So Steve you said something about mixing is that hard to program. I have a DX6 and I don't know if its capable of doing so. Teach me how to do the mixing. But you can always do this KE at normal rudder stick movements right.
Can someone give me a link where I can see 3D and pattern maneuvers. I know I've seen one with sim demo. Thank you very much.
