You could try looking at the instructions for another manufacturer's CUB to help you.
However NP does not have anything better to send you
AFAIK.
We've all been cautioning newbies here, that while the NP ARFs are good values for the money, they are NOT for the first time "builder" (real builders please excuse the use of the word!).
In other words if you really need the instructions, then you should probably put the plane away and built another ARF to get experience building planes.
Once you are at the point that all you really need is the C.G. and throws, then you are ready for the NP planes.
Your best bet is to either wait, or find someone with experience building ARF's to help you.
Usually once you have 2-3 under your belt, how to put ALL of the NP ARFs together becomes obvious.
