ORIGINAL: FSOneDev
skorman -- I recall you mentioning the problem with 1.0.4, and see that now you're encountering it with 1.0.5. We have tested both patches on a range of systems and it has always run fine on each one. In other words, we cannot duplicate the problem you are experiencing, and if we can't duplicate it, it is very difficult to investigate and solve your problem. Nontheless, we want to try to help you get the later versions working on your system.
The first thing to do (if you haven't already done so) is to install the latest video drivers and sound drivers.
You mention a terminal window flashes and then nothing. If you check Windows Task Manager immediately afterwards, do you see an FS One task that is still runing?
Hang in there, we'll try to get your PC working with the latest versions...
Thanks in advance for your help. I have updated video and audio drivers and still can't get it to work. Windows Task Manager shows no task running after trying to start program. I am running Windows 2000 with an AMD 3200 processor, 1 GB of memory and Nvidia 7300 GS graphics board.
