RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 03-25-2007 | 11:18 AM
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
I glued the piece labeled "BP" with 30 minute epoxy.
Torque rod blocks and plywood wing hold-down plates also glued in place with 30 minute epoxy.
Any remaining epoxy was applied to the seam between the wings.
I noticed the plans showed a brace for the aileron servo but found no reference to it in the manual. I will have to add that later.
ID:	649479   Click image for larger version
ID:	649480   Click image for larger version
