Wick246,
The blades will probably work, they are symetrical, the difference in the main rotor diameter is only 3mm. The Honey bee is 530mm and the CP is 527mm.
The center hub won't work, I magnified the picture and there is a difference, the top of the hub is squared off on the Honey Bee, also, in the picture there is an extra part, look just below the two O-rings.
ORIGINAL: wick246
Will the center hub set and rotor blades from the Esky Honey Bee cp work on my cp? I know many parts are the same but some look a little different, not sure which are compatible.
[link]http://www.bphobbies.com/view.asp?id=V019752[/link]
