ORIGINAL: SAVAGEJIM
Thanks! I should have known that: anode=positive for anion ("not ionic" therefore not a negative charge) and cathode=negative for cation (therefore negative charge).
When you say weak sufuric acid, do you mean liquids like used in auto batteries? If so, what is the proper manner to dilute it for this use? How much current must be run through this system for oxidation to occur?
I believe if you're using battery acid, you mix it 50/50 with water...and I believe it must be distilled water...am I correct?
