There are a lot of Esky parts that ARE interchangable. Tail boom, motors, tail motor housing...prices are a LOT lower than Eflite stuff. I recommend using Esky where possible. A little competition will force Eflite to lower their prices and in the intrum...you save a lot of $$$. I did exactly what you said, I ordered 3 tail booms at $1.xx ea not knowing if they would work. Got them in...A direct match and I saved about $2.50 on each one.
ORIGINAL: wick246
Thanks Chopper! I need to slow down the spending until the next check but I will give those blades a shot just to see if they work. There are also 2*6*3 bearings on clearance for a dollar under the E sky 5005 menu on the left. Different part number but correct size. Worth a dollar for me to order some and see if they are the same.
