RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 03-25-2007 | 05:21 PM
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
I applied the fiberglass strip to the wing center section so have moved on the fuselage.
The fuselage doublers have been glued to the fuselage with 30 minute epoxy.
I'm glad the manual says to "Make sure you make a left and a right side!"
Former F1 glued with 30 minute epoxy and clamped tight. The remaning formers are dry fitted.
ID:	649750   Click image for larger version
