RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-25-2007 | 05:28 PM
  #1448
choppersrule
Default RE: Wheeeeeeee.......... Blade CP!
Lookyj,
Hmmm, brain is in gear, thinking........
If I understand you correctly, you can't get the main shaft to get through the bottom bearing of the frame...Get the dremel out and grind some stuff off, only problem with that is you'll never get it perfectly round, then you'll have a tad of slop at the bearing.
Option 2, hmmm, a bearing for the Century, if it would fit in the main frame.
Dave / Choppersrule
ORIGINAL: lookyj
anyone use the Century Gear and Main Shaft with the Blade CP?
CNE219 - Main Shaft, Pin and Collar
CNE218 - HB ELITE
my LHS was out of the micro Heli AR shafts... and the Century AR shaft and gear found on bladecprepair.com... so I bought these to fix up one of my helis...
Once assembed, the pinion on the motor and gear aren't lining up right. It seems there's a more of a collar where the shaft attaches to the gear, keeping the assembly from sliding all the way up...
anyone have any ideas?
