Lookyj,
You'll be surprised with the 10 tooth on there. Just don't crash, it'll fry the 3n1 or 4n1 in a heart beat.. Do the 7.5 amp fuse. Don't even think of Idle-up this way, (a crash in that configuration can be costly) until you get the fuse in there. I've blown a couple fuses, but never a 3n1 or 4n1 that way.
Oh so true, what a vicous cycle we go through... Still Cheaper than Golf or a Harley..
Good luck, keep 'er up, the heli I mean(yuk-yuk),
Dave / Choppersrule
ORIGINAL: lookyj
choppers,
perfect timing on the tip of the day!
I just got the head put together and back on... just need to solder the tail motor and then run the wires!
I decided to go with the dremel and shave off some of the plastic and I'm gonna use the 10 tooth pinion.... lines up perfectly now!
it's starting to look more like a heli and less like a pile of parts.....
THE LIFE CYCLE OF THE MICRO HELI
pile of parts ---> assembly ---> helicopter ---> crash ---> pile of parts
what a vicious cycle..... but ohhh SOOO MUCH FUN
Wheeeeeeeee.......... Blade CP
