DA-100 cold start problem
This problem has just started in the last two months. On the first start of the day, the engine starts normally, but will not transition to high throttle. When the throttle is advanced, even partially, it sags and dies unless the throttle is retarded back to idle. After running at idle for 30 to 45 seconds, thransitions are normal and will continue to be OK for the remainder of the day. Any ideas?
