RCU Forums - View Single Post - Kalteisen O2 in Mexico
Old 03-25-2007 | 10:37 PM
Bolio
Default Kalteisen O2 in Mexico
Here is the finished O2.
Weights 2.75 lbs and uses an OS 32 with a 11x3 APC. Ballistic pull out!!!!!
Still a little nose heavy but flies great.
Feels really light on the wings. Harriers show a very small wingrock but very controllable. Hovers are great Has a very strong will to torqueroll and actualy I let do some of his own, barely moving the sticks
If the wind is calm you can fly some pattern very easily. But as soon as the wind picks up a little, being so light get tossed around a bit.
Flips are insane!!!! I.m using HS81 mg on the tail and HS 85mg on ailerons and rudder. I was kind a waiting for the 81's not being enough but no problems at all, this bird has really a lot of tail auhtority.
Building is great as are all Quinn designs, very precise and accurate everywhere.
I need to add some ProBro decals on the bottom to help in the orientation, can get mixed when is far from me.
Is a really cool plane and I do believe that after some trimming (CG and latteral balance) it will get better.
Saludos.
ID:	650097   Click image for larger version
ID:	650098   Click image for larger version
ID:	650099   Click image for larger version
ID:	650100   Click image for larger version
