RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-26-2007 | 02:23 AM
  #1482
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Wheeeeeeee.......... Blade CP!
LOl............. we are all on a bling craze here! If we all got together and somebody pulled out a shiney object, we would all automatically start drooling.
got the servos working properly, just happened to go thru the TX model memory and there was some settings for a saber from the previous owner. Had the Tx on long enough to get the low battery alarm so will charge it overnite. Getting closer to installing blades and trying to track them. May adjust the main shaft height again, did once already today then centered the servos, almost binding at the top so will work on that a little. Just might be flyable by midweek if things keep clicking. Would love to find a Futaba owner that has a 6EXH to compare settings with.
Choppers, I did the servo wire wrap like you showed, it only makes sense, I used to work on 24V control systems and all of our pairs were twisted too.
crash, excellent idea on the canopy grommet idea.......... I've looked at it a couple times and I like the idea. Funny how things grow on all of us. Still all in all................. Wheeeeeeeeeeeeeeeeeeeeeeeeeee.................. Blade CP!
lookyj, looks really good, got a lot better mesh on that gear now.
__________________________________________________ ________________________________
Of all the things I ever lost......................................... I miss my mind the most!
