RCU Forums - View Single Post - DA-100 cold start problem
Old 03-26-2007 | 05:11 AM
Flyin Woodbutcher
Default RE: DA-100 cold start problem
when the low end is set correctly all DA engines will not transition when the engine is cold. If you richen up to run good cold it will be to fat after it is warm. Sounds like to me you have it set correct. If you put the choke on a servo and use a variable rate on the transmitter you can give it about half choke and it will transittion fine cold.
FWB
