RCU Forums - View Single Post - Raidentech Ultimate Bipe!
Old 03-26-2007 | 10:53 AM
dqman40rock
My Feedback: (89)
Default RE: Raidentech Ultimate Bipe!
I think that this is a great little plane as well. Went together fine and flies well. We fly off grass so wheel pants are out.
Using an AXI 2212/26, 10/4.5 sloflyer prop, 1800 MAH 3S-1P 10 C batteries
Drawing 13 Amps and comes down with cool batteries and motor. Attached is the Static reading from the Flight Data Recorder before the first flight. Havent put it up with the Data Recorder on board yet.
I have to agree with the Nitro Planes customer service being sucky. If you luck out and get a model from them and have no problems with it, you are in great shape. But if you have a problem, you probably need to figure out a way around it your self, because they wont respond to Email, Phone calls or any other method of solving your problem. Fortunately on this one and one other plane, I've had no problems.
ID:	650381   Click image for larger version
