RCU Forums - View Single Post - Wheeeeeeee.......... Blade CP!
Old 03-26-2007 | 04:15 PM
  #1487
ArrowNaughtic's Avatar
ArrowNaughtic
Default RE: Wheeeeeeee.......... Blade CP!
I believe those go in between your O rings and the inner stepped washer, next to the rotor hub.
wick, quit buying up all the good stuff! You found a kit for 100 bones? WTG bud!
crash, servo's were plugged in backwards so had to unwrap em and mark each one after I fixed it, then wrap em back up! I am such a dork sometimes. Next issue at hand, Even with the programmable radio I am unable to reverse the collective pitch. So am gonna have to flip blade grips and the flybar inner frame dealie ( I am not sure what its called) and then am ready to go buy a darn scale, I have major wobble going on just starting to spool up. I have my second throttle point set at 21% right now, didn't want to take off to quick until I get a smooth wobble free spool up.
__________________________________________________ _________________________________
Of all the things I ever lost............................................ I miss my mind the most!
