RCU Forums - View Single Post - BCX2 Flybar Frustrations
Old 03-26-2007 | 09:43 PM
slip_stream
Default RE: BCX2 Flybar Frustrations
Follow the instructions of soloboss. Pretty much after a crash, or if my chopper vibrates, i break everything down, balance, check, and make sure that everything is running smooth.
example make sure that the inner and outter shaft dont shake. Run the chopper with out any blades.
Put on the bottom blades, run the bottom blades. Make sure that there is no shake, they are balanced, and that they spin on the same plane.
put on the flybar, run the top rotor, again, level, and no shakes.
put on the top rotors, balanced, and again, they spin on the same plane.
Note, the blades on the top near the hub, have numbers, make sure that they numbers match. If they dont its almost guaranteed they are different weight.
This will get you a chopper that does not shake in the air.
