RCU Forums - View Single Post - Bad esc or something else?
Old 03-27-2007 | 06:03 AM
Dirtee bug
Default RE: Bad esc or something else?
I started to switch my esc and try a different one to see if the esc was bad and I decided to power up the heli after moving ( not rerouting) some wires around, moved the esc from the bottom and just let it hang from the side and took it outside to give it one last chance, and everything worked with no cut out, I cant believe moving some wires around would do that since its been flown before with the wires routed the same way
