RE: Project AXE CP Main Gear Transplant
Did my field test (5 Packs and a hour later) and every thing went well. The 14T pinion is a bit much for the head speed, I'll try a 11T and see how it goes. Still waiting for the parts so I rigged the main shaft to keep the gear in place. Drilled a hole above the gear and installed a screw and nut.
