RCU Forums - View Single Post - gas fuel with glo plug no ignition
Old 03-27-2007 | 02:36 PM
  #1154
AndyW
Default RE: gas fuel with glo plug no ignition
Roosterlew,
The plastic insert is there to isolate the carb from the heat of the cylinder. This isn't a problem on a standard, model engine because the carb is mounted to the much cooler crankcase.
An 18cc with everything possible stripped off of it might make a neat, reasonably light engine. What brand? Can you supply pictures as you affect the conversion? How about posting a clip to YouTube with your results?
