RE: Alternative AXE CP parts
Well I got the new [link=http://rcsmart.com/bladeswood.html]Blades[/link] in. Not worth the time money.
They were shorter then stock and they were suppose to be 260mm. I had to
cut out one side of the plastic and shave the other to fit into the grips. The
2mm holes were in the plastic and not the blade. I had to fill the hole with
CA and drill out. I also got my new lipo batteries. So I balance the blades
and put everything together, crank her up, takes a little more RPM to lift off.
She seems to be flying good, I need to dial in a little tail trim, did I set it down
to do this, no, so thirty second into my flight with the new blades and batteries.
Slips side ways, one blade dust, and my new tail rotor housing broken. [:@][sm=crying.gif]
