enginetrouble
I use 15% nitro and use the pinch method to check the high speed needle valve. With the engine at or near max rpm pinch the fuel line,the rpm,s should go up 300/500 rpm,if not readajust the valve,after setting I point the plane vertical,if engine dies or begines to lean out then richen a bit.
