RCU Forums - View Single Post - engine mounting
Old 03-28-2007 | 12:56 PM
MinnFlyer's Avatar
MinnFlyer
Default RE: engine mounting
Basically, yes.
If you are mounting the engine upright or inverted, the vertical line on the firewall should be centered between the two mounts and the horizontal line should line up with the tops of the mounting rails ( "TOP" meaning the side of the rail that the engine will be bolted to).
If you're mounting the engine horizontally, switch the previous instructions.
