RE: gas fuel with glo plug no ignition
AV8TOR,
Thanks for the lead on a Big Stik. That gives me specs to shoot for. I've got the original RCM plans and will likely blow them up to size. The GP Stik looks perfect for the Poulan but 13 lbs on the 26 will leave me wanting. I like vertical a lot, so may make mine 70" span or so and keep it under 10 lbs.
Also, the original had a bit of dihedral. I've flown both with and without in the standard size and the bend in the wing I find a bit more flyer friendly. Just me. I guess I need all the help I can get. [:@]
