RCU Forums - View Single Post - Sig Extra 300 Arf
Old 02-25-2003 | 10:14 AM
Red7fifty
My Feedback: (73)
Default Sig Extra 300 Arf
I used the kit hinges put in with 30 min epoxy, The Dubro's are good too, so are the Klett and Robarts. The Sig Brand X works good, had no problems. A little tip I use is to rub Chapstick on the hinge knuckle so epoxy doesn't get in there, and "blow" some epoxy in the slot with a drinking straw, that helps make sure youv'e got enough glue. After the glue FULLY cures, pull the hinges to make sure they stay put! I've seen surfaces fly off due to poor installation. Good luck.
