RCU Forums - View Single Post - Dimension Engineering
Old 03-29-2007 | 12:04 AM
Rathead123
Default RE: Dimension Engineering
ORIGINAL: pscartozzi
I justed checked the voltage on my setup. My cell is 6.7V at OCV. THis seems low but it's a new pack. Hooking up the ESC made no difference. Weak driving draws the battery down to 5 Volts and the thing resets. Are you guys using NiMH batteries?
Is this normal
Not familar with that DMD ESC, but sounds like the battery's either bad or somehow didnt charge up right. Or you have a REAL high current drain. Most 7.2;s read 8.7 or so when "hot", and most current draws shouldn't pull them below 7.2 to 7 volts... I also have 3300nimh in my bulldog..
