I didn't read the link posted by MinnFlyer and it probably covers this, but in case it doesn't, I'll just add my two cents:
ALWAYS vacuum the model prior to covering. Don't just use a tac rag because it won't get all the dust off. The covering will not stay down if you cover over a dusty model.
If you have an air compressor, then this is the order to go in:
1) Sand model (repeat until three times after you think you've sanded enough.
2) Blow dust from model.
3) Vacuum model.
4) If you find something that needs to be fixed, fix it and return to step 1.
5) Start covering.
Good luck. I went with greenboot's option 3 as well. Unfortunately, it did kill me, but as luck would have it I'm immortal, so I lived to tell about it and try again.
