RCU Forums - View Single Post - Dx7 setup for the T-Rex Se V2
Old 03-29-2007 | 11:55 AM
cflight
Default RE: Dx7 setup for the T-Rex Se V2
O'boy where to start?
First you need your servos moving in the right dirrection. Set swash mix for 120 degrees. If all three or two of three are moving in the wrong dirrection, change the swash values to -60.If one is not moving the right way go into reversing menu and reverse that servo.
My settings are:
normal mode:
pitch curve 40%,50%,75%,100% this gives you a little negative for windy conditions
throttle cuve 0,65,80,90,100 this keeps your motor in the power band
stunt 1 :
pitch curve 0,25,50,75,100
throttle curve 100,90,80,90,100
Any thing after half stick is a smoth switch.
I run gear to gyro with settings in gyro sense menu at 0=72 and 1=30 for the GY401 and 9650 servo with a subtrim of 45 right for rudder to set the tail still in rate mode
