RE: Disadvantages of Non-recommended size Props
Thank you very much for your replies,
I understood it very much, but there are 2 points which I need the clarification, pitch is used for speed, higher the pitch higher the speed, and higher the diameter higher the thrust, thrust is the force which pushes in the backward position, so, it can be said that if the thrust is higher speed won't be much, or what exactly the difference is between thrust and speed in technical terms.
Mody
