RCU Forums - View Single Post - Disadvantages of Non-recommended size Props
Old 03-29-2007 | 09:20 PM
B.L.E.'s Avatar
B.L.E.
Default RE: Disadvantages of Non-recommended size Props
ORIGINAL: CGRetired
Normally, the power listed for a specific 2C engine is at a specific RPM. Most flyers don't approach that RPM because it is way to high and sustained operation at that RPM may eventually cause problems. Also, the noise level at that RPM is sometimes not tolerated at certain clubs. Remember that noise does not necessarilly equate to power.
For instance: The OS 45 AX engine shows 1.65ps at 16000 RPM. Operating it at RPM would probably drive every one crazy and would use a small prop. Normally you may operate that engine at a peak RPM of about 12000. This would probably work out well using the props listed above.
I normally use a 15-10 prop on my OS 1.20 AX. That gets me a peak RPM of about 9800. I chipped that prop and the only one I had on hand that was balanced was a 15-6. It tached at about 11000 RPM and was very noisy. The prop tip speed was making tremendous noise and the prop was not that efficient. The original prop would have been much better.
I'm sure lots of people would shoot for the max RPM they can get, but that normally equates to short engine life. You are better off sticking to what is recommended and working around that number.
DS.
Another thing to consider is that the higher prop efficiency of a larger slower turning prop offsets the engine power loss of the lower rpm. This is why four strokes and electrics perform so much better than their horsepower numbers would indicate. The optimum prop is actually a tradeoff between one that's small enough to let the engine perform and yet big enough to let the prop perform.
Put a gear reduction unit on a .46 two stroke and then you could use its 1.6 horsepower at 16000 rpm to turn a 16x10 at probably 8000 rpm for enough thrust to take an 8 pound plane verticle to the moon.
