RE: Tiger 1 is done(more PICS by request)
Your first time effort is pretty impressive, great job. I agree, I think it needs to look even more dirty and used up. If you feel like working on it more, I suggest you maybe chip off some zimmerit and simulate rust in that areas. I have a 2 part rust finish I got at Michael's craft store. You paint on a iron oxide layer, then coat is with a rusting solution, it creates real rust on any surface. Check out a crafts store and you'll see what I'm talking about, it's worth the $10. You can also heat up a blunt metal object and melt a shell richochet into the hull and/or turret. A smaller hot object could mimic small arms fire damage.
