RCU Forums - View Single Post - FS One by Hangar 9
Old 03-30-2007 | 06:52 AM
  #822
sctholson
Default RE: FS One by Hangar 9
Hi Michael,
Thanks for creating the FAQ, thorough, great. I followed it without a hitch. It'd be nice to have a choice of field of view in the options menu in a future release.
My Garage Picture is attached. I still need to move the heli over to the right and set it as the new starting point. Also, I want to change the elevation of my view, as if my head were tipped up just a little, any tips on how to do this? Is this the horizon change you mentioned in the FAQ:
"To change the direction of north in the pano, open the PanoExample.dom file and edit the Azimuth (deg) value. Changing this Azimuth value will rotate the dome (pano). Changing the Pitch (deg) and Roll (deg) in the file will tilt the pano and can be used to make the horizon in the pano line up better with the ground elevation (level in this example). To move the sun position, edit the Azimuth (deg) and Elevation (deg) values in the Sun section of the file. To turn on/off the lens flare, set the flag to 1/0. These sections are shown below:"
Maybe you could add to this portion of the FAQ whether a positive number moves the image left or right, and up or down.
Thanks for the reminder on the "A" Zoom key.
