RCU Forums - View Single Post - Top rotor not spinning!
Old 03-30-2007 | 09:43 AM
FMB42
Default RE: Top rotor not spinning!
I had a main motor wire come loose on one of these and was able to re-solder it to the board. Just be careful that you don't pull any other wires off of the board or motor while you do this, if this is the case. And yes, I made this mistake. BTW, this 40 dollar HF heli is still flying and has over 90 battery cycles on it. Good luck and good flying!
