TMaxx clutch question...
HEY WOOKIE YOU MIGHT ALSO CHECK THE INSIDE OF THE CLUTCH BELL FOR GLAZING IF IT IS GLAZED .TAKE ALITTLE PIECE OF 3M SCOTCH BRITE PAD AND CLEAN IT OFF OF THE END-BELL THAT SHOULD GIVE YOU THE LIKE NEW FEELING AGAIN............ALSO CHECK THE CLUTCH FOR CRUD IN-BETWEEN THE SHOES OR EXCESSIVE GLAZZING ON THE SHOES
