RE: Substitute for Ether
Treven, the idea came from the evaporation and lubrication discussion we had. I'm not sre if it was this thread or not. The idea is the charcoal lighter has a narrow boiling range that is lower than that of kerosene. This might lead to more of the fuel component evaporating, for better lubrication and reduced fuel consumption.
I think that cetane rating isn't everything. We can change it as we need with cetane booster. I added 2-3 times what I normally use by mistake once and it certainly advanced ignition timing to the point I couldn't use the mix.
Some of the other MSDS I looked at said the lighter fluid was Stoddard solvent. There are only a few available here. I'll have to look around at stores to see what else I can get.
