RE: Ts Oxalys build
Hi!
Have flown about 10 flights now and the plane starts to fit my fingers , or maybe my fingers have change to fit the plane....well forget that!
my CG is now placed 22 cm from l.e. ....this is without the belly pan and wing ..just fuse! Havent messured with wing ..but adjusted it to it fit me , it maybe needs some more ..but not much.
It snaps wery fast and clean (uses max ailron and less elev. and rudder) .
Spin dont need as much elevator as on my Twister if i use to much its almost goes into flat spin , so use normal mode on this so fare.
So , what can i say , the planes flies like a dream and handels lovely!
I had some problems to get it roll nicely in the first flights but i think that just was my winter cold fingers that needed some sun!
Rune
