RE: I Killed it !!!!
here are some rx specs showing voltage as low as 3.6 volts this is one of those thing that can be argued back and forth but for some reason i keep posting that link to flying giants which is talking spectrum rx at 3.6 volts.but here is a futaba spec and a gws spec of rx voltage
Futaba Lo and Hi Band 8 Channel PCM Receiver
All Mid Size / Full Size Helis
The Futaba R138DP is a 8 channel PCM receiver. Narrow-band spacing and dual conversion signal filtering combined to provide exceptionally clear, interference-free reception and amazingly smooth, accurate control. Designed for modelers who want to
use a single radio transmitter to fly several different model aircraft, especially pilots who are utilizing computerized radios with multi-model memory.
Channels: 8
Band: 72MHz
Conversion: PCM
Operating Voltage: 3.5-6.0 Volts
Range: 6,000+ Feet
Antenna Length: 39”
Spacing: 20KHz
Case Size: 2.5” x 1.38 x 0.88” (63.5x35x22mm)
Weight: 1.75 oz. (50g)
Go back to: Products > Receivers
View Cart
GWS R-4PII/T Pico Receiver for Airtronics/JR Radios $19.20
GWS R-4PII/T Pico Receiver with Micro JST Connector for Airtronics/JR Radios
Quantity:
This receiver comes with Micro JST connector and is designed for slow/park/indoor flyers. Servos and ESC must have Micro JST Connector to work with this receiver.
Specifications:
Number of Channel: 4
Modulation: FM (PPM) Single Conversion
Signaling: Positive Shift
Operating Voltage: 3.6 to 7.2 V
Current Drain: 5 mA
Weight: 3.6 g (0.13 oz)
Dimensions: 15.0 x.25.0 x 9.5 mm (0.59 x 1.00 x 0.37 in)
Range: 150 m (500 ft)
