RCU Forums - View Single Post - Afthershock problem
Old 03-31-2007 | 08:48 PM
Grits
Default RE: Afthershock problem
If the engine is cold, check for leaks, etc as described. If the problem occurs while the engine is hot, there needs to be more air flow to the engine and/or richen the HSN a bit. When engine gets too hot it can cause the fuel to boil at the carb and this is what you would typically see with the fuel not getting to the carb.
