RCU Forums - View Single Post - My GST Just wouldn't go!
Old 03-31-2007 | 10:54 PM
The Real Dogman's Avatar
The Real Dogman
Default RE: My GST Just wouldn't go!
Unlawful, Would you rather buy it in kit form and assemble it yourself. Then maybe there wouldn't be as many issues of screws coming loose. Well, any RTR you buy, you definitely need to go thru the truck completely and check every screw. Especially those that are KNOWN to be loose or not installed propoerly at the factory(as fast as they are assembling them you just know the time is not really taken to get the grub screw on the flat portion of the pinion shaft Before tightening)
Anyway enough ranting, Good points tho..
