RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 04-01-2007 | 09:00 AM
  #33
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
The next thing I did was measured, cut, dry fitted, then glued in place the stringers.
I then dry fitted the wing.
It was too tight so I had to remove some wood from the aileron torque rod hinges and the fuselage where they met.
I glued in triangle stock to the firewall and fuselage doublers. Note the cutouts for the blind nuts.
ID:	654287   Click image for larger version
ID:	654288   Click image for larger version
