RCU Forums - View Single Post - SIG Fourstar 40 (4*) Build Thread
Old 04-01-2007 | 09:08 AM
  #34
rwright142's Avatar
rwright142
Default RE: SIG Fourstar 40 (4*) Build Thread
I fitted and glued the wing mounting dowel into the wing.
Before drilling the wing mounting holes, I used string to make sure that both ends of the wings were the same distance from a point at the end of the fuselage. I had to 'scoot' the wing sideways just a little to achieve this. I then drew a line on the fuselage and the wing to use as a guide before I drilled and tapped.
Notice a small gap between the wing bottom and fuselage - I don't think it will be a problem.
The landing gear is off center. I won't know how badly this will affect taxiing until I get the tail wheel on, but does anyone have a suggestion for a fix? Should I be able to slightly bend the aluminum where the wheels screw in?
ID:	654298   Click image for larger version
ID:	654299   Click image for larger version
ID:	654300   Click image for larger version
