RE: My GST Just wouldn't go!
To prevent the balloning, is directly related to driving style and setup. First the driving style.. When you see the balloning,,Let off just a touch. The setup requires thicker diff fluid and sway bars. Locking the center diff will also help the balloning. If you lock all there diff's wil cure the balloning but will kill your drivabilty and drivetrain parts will wear very fast so you will have to find a happy compromise with thick diff fluid, driving style, sway bars(you will have to fab your own, or order a set from me) and center locked diff. I any case the combination will differ for all, so experiment and see what works best..
Duct Tape works to stop the balloning but does not cure the unloading of the diff that causes breakage...
Good luck and have fun!!
