RE: GST Working Fine, Now it wont go anywhere
First thing is be more careful with your posts dont post quickly after a post. Use the edit feature if you need to add something to your previous post.
Anyway take the clutchbell off and see if the shoes are hung up.
As for the balancing of you clutchbell just put it back on use a dremel to grind a small amount of material from the outside of the bell but be sure you spread/feather out your grind so you dont create at groove(weak point). just take very small amounts off at a time and continually check your work. Take your time.
I have found out 5 bells I have bought, three were out of balance, I want to check the flywheel, so I think I am going to invest in a prop balancer for these tasks
Have fun!!
