Originally posted by warhoover
i was also thinking about replacing the system with 2 carbon fiber control rods instead to avoid possible rf interference.
Carbon fiber make a fairly good antenna and as such would not help with RF or EM interference.
Captianpitts is correct although, because pull-pull only works in tension, for the realitivly low loading on the Taylor 2-56 will be more than strong enough. The 4-40 systems only become ness when several servos are ganged. I can actually hang from the dubro 2-56 cable and I weigh about 180 pounds.
