RCU Forums - View Single Post - Top Flite Cessna 182 build
Old 04-02-2007 | 02:40 PM
  #65
teookie's Avatar
teookie
Default RE: Top Flite Cessna 182 build
Thanks, deadeye for posting your pics and sharing your ideas. We need as much of that as we can get on this thread!
There are so many options you can build into this plane it makes it a really exciting build. Even though most of the airframe on mine is done, I don't think I'm even half way through building yet.
I managed to get the wing mocked up on the fuse, as I'm sure we are all prone to do once we have semi-complete components:
I decided that I needed to sheet the bottom of the wing before deciding if and how I should modify it (it is not sheeted in this pic). I may end up sheeting the top so I can remove the flaps, and get a better view of the wing to fuse interface.
I have also cleaned up my workbench. It was messy after sheeting the fuse!
