RCU Forums - View Single Post - brushless set up and question
Old 04-02-2007 | 05:03 PM
pitch
Default RE: brushless set up and question
Thanks for getting back to me. Yes it is a blade pro. The issue that I am having it that the tail is wagging quite a bit. I have already looked at the sensitivity and am presently trying to fix. But , I am starting to think that the problem may be the fact that the gyro is quicker and more responsive than the motors can give back.
I did find that in my dual tail set up one motor was burned out, so that in itself would cause some problems. Bought a new motor today so we will see if that solves the issue. But I do not think that I should have to change to a brushless or a DD just to use a gyro.
I will keep you posted as to my results.
Andrew
