No...one drop on the joint, and it'll twist right out. The bad part is that hard landings also loosen the glued joint.
ORIGINAL: Wnuk
Do you think CA glue is a little too strong in case I (inevitable!) have to remove it again? CA is tough stuff bot I never used it on anything CF before.
Harbor Freight is an awesome store. I can always find a good buy each time I stop there. Sometimes too many good buys[&o]
