RE: Beginner questions for WSN T34
I am in the midst of this very project, i used the innards of a HL Panther. I am about 80% complete. The WSN RC is crap compared to the HL S&S unit. I have the metal tracks and stock gear box, I will run this till it gives trouble, then I will look at either using a HL metal gearbox or buying the metal gears. I didn't solder the motor wires directly to the HL board, if you tin the HL wires thick enough they act as plugs that go securely into the WSN motor harness. I will post pics shortly in the original build thread I started for my project.
