RE: Prop Drill Jig for Evolution 58GX
Pe
Legs are fine, can't say the same for the muscle groups though.
On the drill jig, the use and supply of an undersised drill to make the hole in the prop and then using the also supplied clearance drill to ream out the hole is a nice touch, and ensures the correct sized hole perfectly vertical within the prop hub. The only thing they could have supplied to help even further is a short bolt or stud to put into the first drilled hole to ensure nothing moves when you drill the subcequent holes, easily got over with a short piece of piano wire though. Still a very impresive piece of kit, very pleased with it. I think I will buy some new props just so I can use it more.
Mike
