RCU Forums - View Single Post - inverted engine issue
Old 04-03-2007 | 09:32 AM
Pete1burn
Default RE: inverted engine issue
Priming is turning the prop manually (WITHOUT a glow starter on) to feed fuel into the engine before starting it. Unhook the muffler fuel line, plug the carb with your finger, turn the prop two or three times. This feeds a small amount of fuel into the engine to start it easier.
